LIST seems to ignore the Tracking setting
Hello,
I am running some LISTs, and I'd like all my output in one go. I tried changing the Tracking setting as per the command reference, but "Press ENTER to continue...:" seems to appear at the same interval.
Please see an example below.
Either me or Bricscad must be misunderstanding the meaning of the Tracking setting, which is it?
: LI
SOrt/Tracking/<Select entities to list>: t
Number of command lines to track <4000>:
Opposite Corner:
Entities in set: 4
---------- Viewport -----------------------------------------------
Handle: 10000694
Current space: Paper
Layer: 0
Color: 256 (BYLAYER)
Linetype: BYBLOCK
Center point: X= 67.786 Y= 76.091 Z= 0.000
Width: 99.516
Height: 128.660
Viewport display: On
Handle: 100005DF
Layer: 0
Linetype: CONTINUOUS
Center point: X= 261.883 Y= 366.111 Z= 0.000
Width: 466.460
Height: 86.692
---------- Insert of Block ----------------------------------------
Handle: 100005BB
Layer: ZZ-Border
Linetype: BYLAYER
Block name: nrA0dwgno
Description:
Insertion point: X= 0.321 Y= -179.141 Z= 0.000
X scale factor: 0.708
Y scale factor: 0.708
Z scale factor: 0.708
Rotation angle: 90°0'0.00"
---------- Block Attribute 1 --------------------------------------
Handle: 100005C2
Layer: ZZ-Title Block
I'm on Bricscad 18.2 if it matters.
0 -
The behaviour is by design I think.
The number of lines displayed appears to be "stopped down" to the size of the textscreen Window (as toggled on and off with button). So unless you have an absolutely massive screen - a tracking Setting of 256 or 4000 would make no difference, but a smaller number eg 20 would.0 -
The number of lines displayed appears to be "stopped down" to the size of the textscreen Window (as toggled on and off with button). So unless you have an absolutely massive screen - a tracking Setting of 256 or 4000 would make no difference, but a smaller number eg 20 would.F2 button I meant
0 -
Thanks Dan, I tried it just now and it seems to work exactly like you said.
@Mateusz Lawrynowicz said:
Either me or Bricscad must be misunderstanding the meaning of the Tracking setting, which is it?Guess it was me then. The original post was based on a bad understanding of the problem in the first place, (and what I am trying to achieve is quite far from what I actually asked for) so I started a new thread here: forum.bricsys.com/discussion/35661/get-all-output-from-list-without-having-to-press-enter-to-continue
Your input would be very welcome.0
