Trim/Slice a Surface with a surface
Can I trim or slice a surface with a surface?
  • Yes - use the Slice command with surface option.
  • CADMebel
    Worked great. Thanks!
    Is there a way to slice a solid with a TIN surface?
  • I have been unable to slice a TIN surface or a tin solid with a surface to get a profile.
    Works okay on simple solids created but not with TIN solids or surfaces.
    Any suggestions on how to create a Profile image of a TIN solid?
