Supported Communicator file import and export versions
Is there a way to query Communicator for a list of supported formats and versions? For example, the help.bricsys.com Communicator article shows "SLDASM, SLDPRT: Solidworks" but not the release versions of Solidworks which can be imported.
I have a colleague who needs a Solidworks 2020 file converted to STL for a prototype run but I'd rather not execute a non-disclosure agreement only to find out that I can't import and convert it for him.
I'm sure that this is something which the developers know and also sure that asking each time this may come up "Is (year/release) of (program) supported?" will get an answer. It would be awesome if the COMMUNICATORINFO command could be extended to support this, though.
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
