shape: what is the last version? Where to download?
I have an installed shape since about one year, Version 19.2.06 (x64) revision 61033
I want to know which is the actual last version available for Windows 64bit. There is absolutely no information about the version numbers on the bricsys shape website.
Where can I download it?
If I click on "download shape" in the website of shape, I get a file called "Bricscad V20". The same, if I click the "update" menu in Shape.
I don't understand what I should do with Bricscad instead of Shape.
There is no more extra Shape download package since V20.
Shape is included in a single Bricscad V20 package now.Download, install it.
When you start you will see a screen to choose from all Bricscad versions.
You can start from any version you have licensed,
(Shape only in your case)
and can 30 day try or buy/upgrade all versions you haven't licensed
from there too.0 -
Thank you!
0
