Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Problem with polylines with a lot of vertex
Hello, I have a problem with bricscad, when I have a polyline with a lot of vertex when i select it it takes a lot of time to process (200 vertex or more). This doesn t happen even with a very old version of autocad. It has happen to you? Any ideas?
  • edited February 11
    Quick experiment with a PL with 800 vertices shows a negligible delay. Try turning GRIPS off. Perhaps also look at SELECTIONMODES.
  • It worked with grips off, I would like to see the grips, but meanwhile I ll turn them off when the polylines are too big. Thanks
  • Note that for me the delay is negligible. So your experience with a PL with 200 vertices ('a lot of time') seems strange.
  • @PedroParamo
    Send in a support request and attach a drawing you have the issue with. Our analysts will be glad to look into your issue and try to help you out.
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
