Materials having annotative hatches
Hi
I am searching for the options to make hatches work annotative in generated sections.
Is this possible?
Sorry to distract,
as I don't know the solution.But when I looked your screen shot I was shocked how bad the
dark mode works in this case. The contrast of the Window top bars
destroys everything and distracts from actual content.0 -
^ noticed that in the past with Mac Versions too.
But didn't use multiple view panes since years.But for your initial question,
can you elaborate a bit what you mean by hatches
in physical materials should "work annotative"0 -
@Hans Lammerts said:
Hi
Is this possible?
Hans,
what exactly do you want to achieve? The hatch scale is set by the section scale so 2 sections with a different scale on one layout should have the same hatch appearance.0 -
Change of scale leads to different hatching.0
To have different Hatches depending on scale ?
Like for standard plans, details, overviews ?Or according to new feature of LOD.
I tested only a little bit,
but my approach was always to get some simplified look in
Sections without any Hatches, just black or gray color fill.
I tried to play with Section Properties and in Material Settings.
But wasn't able to avoid Hatches for cutting areas at that time.Could Section Style edits help in your situation ?
0 -
No not LOD or any of that.
I would like to have the ability to use multiple viewports on the same generated section.
I order to do so the hatches should be annotative. The same old principle like texts and dims.0 -
Hi Hans this is indeed not possible with the same sectionblock. A new section on another scale has to be made to obtain this.
0 -
Ok Piet, Thanks for confirming the limitation.
I do not understand why a generated section can't have a annotative hatch definition.
Its sound like a 'missing tickbox' to me0
