Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Parametric Blocks in classic version of Bricscad.
  • Hi
    From the Website:
    BricsCAD classic is working with Dynamic Blocks:
    If you insert AutoCAD dynamic blocks into your BricsCAD drawing, you can, in most cases, edit those block instances. You cannot, however, create or edit dynamic block definitions in BricsCAD. Instead of offering dynamic block functionality, BricsCAD focuses entirely on parametrics. It allows you to create both 2D and 3D block definitions using the same set of tools and workflow.
    Regards
    Wolfgang
  • edited March 2020
    Thanks,
    I am not asking about dynamic blocks.
    I am asking if i can with licence of Classic version BricsCad to make new 2D Parametric Blocks.
    Thanks
  • edited March 2020
    Hi,
    sorry for not reading well.
    From the help:
    "All the tools you used to define the 2D parametric drawing are available in every edition of BricsCAD including BricsCAD Classic. However, to insert the drawing as a parametric block, you must have the Platinum edition."
    Regards
    Wolfgang
Origami
Origami is the Japanese word for paper folding. ORI means to fold and KAMI means paper and involves the creation of paper forms usually entirely by folding.
Powered by VanillaForums, Designed by Steam
