Mouse issues via VPN access
With the COVID pandemic going on, we have largely switched to remote accessing our computers via VPN. Working in paper space or model space is no issue, however we've noticed some issues when working within a viewport. The mouse becomes sluggish, and it jumps around like crazy. It doesn't move far, just a lot. It's almost like someone is on the other end moving the mouse around in the office. Has anyone else run into this issue, and is there a fix for it?
0
you likely need to provide more info. I have seen bcad go sluggish like that with things like point clouds.
tell us about your vpn speed (speedtest.net) and what is in that drawing.
Does it happen on a new viewport? how many vports are in the paperspace?0
