Arc and angle constraints in 3D environment
Seweryn
edited April 2020 in 3D Modeling
Hello,
I want to create simple parametric water sprinkler. It is supposed to have radius parameter ( for the range of the water) and angle parameter - to control the area around the sprinkler. For "area of effect" I dont want entire circle but only half of it. I managed to create two working radiuses with arcs following them but when I apply radius constraints to the second arc it rotates.
Everything is fine as long as only one arc has radius constraint:
But it looks bad so I want to have two identical arcs. After applying radius constraint it rotates:
I dont know what may be the problem. I am new to BricsCad but I finished all tutorials from learning section, BIM training and read V19 manual about constraints. There must be misteake I am making, possibly because I am used to Revit.
Attached is Sprinkler file. I would be grateful for telling me what I am doing wrong.
