To run Visual Basic, you will have to install VBA6
I have installed IntelliCAD 4 PRO and when I select Visual Basic Editor I get the message:"To run Visual Basic, you will have to install VBA6. Se readme for more details". My operating system is Windows 10. Some time ago I managed on another computer, with the same operating system, to install Bricscad 4 PRO and work correctly.
Irinel, do you have a question for the forum? The only problem I see in your post is that you didn't say you have downloaded and installed VBA6. Did you do that?
Howdy, Stranger!
