Findfile BCAD vs ACAD small difference
Hi Forum,
In ACAD there is a quick way to get a parentfolder of a folder using lsp findfile function with the 2 dots ".."
(findfile "C:\Folder\Subfolder\..") will return: "C:\Folder"
Bricscad will return "C:\Folder\Subfolder\.."
Is there a more simple way to get the same in BCAD or only to "string manipulate"
(PS! I am writing double backslash, but seem to get removed when posting)
BR
Carsten
Hi, Carsten,
interesting effects, indeed :-)
I think, using (vl-filename-directory) 2 times should work ... passing the result of first call to the second call (not tested yet);
but I will try to implement the same behaviour for BricsCAD's Lisp engine ...hope this helps & many greetings !
meanwhile (findfile) has been improved to match that AutoLISP behaviour :-) Will be in V21 then.
many greetings ! -
I noticed this difference in behaviour many versions ago in BricsCAD, but concluded that BricsCAD LISP was more correct in behaviour. In every directory there is always a file called "." & ".." , BricsCAD LISP returning this with findfile is consistent behaviour to me IMHO.
In BricsCAD to find the subfolder you would use
(findfile "C:\\Folder\\Subfolder\\..\\") "C:\\Folder"
However, this form won't work in AutoCAD
Perhaps it is possible to add compatibility to AutoCAD whilst retaining BricsCAD's existing behaviour.?
Regards,
Jason Bourhill
BricsCAD V20 Ultimate
CAD Concepts -
Dear Jason,
in V21, both notations will work :-)
(findfile "C:\\Downloads\\Core\\..") "C:\\Downloads" (findfile "C:\\Downloads\\Core\\..\\") "C:\\Downloads"
many greetings !
A late thanks for replies and input on this.
Howdy, Stranger!
