Pline get co-ords stop working
I have been using a simple entget method for the pline co-ords and its just stopped working.
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entlast)))) this returns only 1 point and its 0,0,0
(command "pline" "0,0" "2,2" "0,2" "")
Autocad multi dxf 10's
(entget (entlast))
((-1 . ) (0 . "LWPOLYLINE") (330 . ) (5 . "11C6C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "DEFAULT") (100 . "AcDbPolyline") (90 . 3) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 2.0 2.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.0 2.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0))
Bricscad only 1 dxf 10 and wrong
(entget (entlast))
((-1 . ) (0 . "POLYLINE") (5 . "A1") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (370 . -1) (100 . "AcDb2dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 0) (40 . 0.0) (41 . 0.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (210 0.0 0.0 1.0) (75 . 0))
You can see Autocad has multiple dxf 10's
I have other methods VLA, entnext but this was a simple one liner and its in lots of my code.
Any ideas why it has stopped working I am sure its in a variable somewhere.
Just retried in my older V19 not V20 and it works fine, so I have set something during programming. Still stuck.
((-1 . ) (0 . "LWPOLYLINE") (5 . "A2") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (370 . -1) (100 . "AcDbPolyline") (90 . 3) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 124.0 64.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 244.44369756722 205.736783215706) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 440.84914421148 125.931391615458) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0))
Its working now not sure but I think osnapz changed but have to close Bricscad and reopen to reset. Will try to find.
"POLYLINE" vs. "LWPOLYLINE"...
You are creating 'heavy' polylines in BricsCAD. Look at the PLINETYPE variable. -
Also, when passing points, make sure that object snap is not active !
(setq oldOsmode (getvar "osmode"))
(setvar "osmode" 0)
(command ...)
(setvar "osmode" oldosmode)and restore "osmode" afterwards :-)
Thank you for the comments.
I have been programming Autocad for 30+ years so when something like this happens it gets hard to work out what has changed, nothing obvious, hence the simple test draw a "PLINE" then (entget (car (entsel "pick pline"))) and only 1 dxf 10 was appearing.
I just used logfile from both versions and did a compare trying to find some thing different. Still not real sure which variable fixed problem.
As Roy mentioned, it is PLINETYPE which defines whether "old-style" or "lightweight" polylines are created;
3D polyline is unaffected :-)
many greetings ! -
That appears to be the answer I have no idea why it would change. Not in my code in some ones code I have tried to hep with.
Thanks again.
Howdy, Stranger!
