Pline get co-ords stop working
I have been using a simple entget method for the pline co-ords and its just stopped working.
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entlast)))) this returns only 1 point and its 0,0,0
(command "pline" "0,0" "2,2" "0,2" "")
Autocad multi dxf 10's
(entget (entlast))
((-1 . ) (0 . "LWPOLYLINE") (330 . ) (5 . "11C6C") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "DEFAULT") (100 . "AcDbPolyline") (90 . 3) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 2.0 2.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 0.0 2.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0))
Bricscad only 1 dxf 10 and wrong
(entget (entlast))
((-1 . ) (0 . "POLYLINE") (5 . "A1") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (370 . -1) (100 . "AcDb2dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 0) (40 . 0.0) (41 . 0.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (210 0.0 0.0 1.0) (75 . 0))
You can see Autocad has multiple dxf 10's
I have other methods VLA, entnext but this was a simple one liner and its in lots of my code.
Any ideas why it has stopped working I am sure its in a variable somewhere.
Just retried in my older V19 not V20 and it works fine, so I have set something during programming. Still stuck.
((-1 . ) (0 . "LWPOLYLINE") (5 . "A2") (330 . ) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (370 . -1) (100 . "AcDbPolyline") (90 . 3) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 124.0 64.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 244.44369756722 205.736783215706) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 440.84914421148 125.931391615458) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0))
0 -
Its working now not sure but I think osnapz changed but have to close Bricscad and reopen to reset. Will try to find.
0 -
"POLYLINE" vs. "LWPOLYLINE"...
You are creating 'heavy' polylines in BricsCAD. Look at the PLINETYPE variable.0 -
Also, when passing points, make sure that object snap is not active !
(setq oldOsmode (getvar "osmode"))
(setvar "osmode" 0)
(command ...)
(setvar "osmode" oldosmode)and restore "osmode" afterwards :-)
0 -
Thank you for the comments.
I have been programming Autocad for 30+ years so when something like this happens it gets hard to work out what has changed, nothing obvious, hence the simple test draw a "PLINE" then (entget (car (entsel "pick pline"))) and only 1 dxf 10 was appearing.
I just used logfile from both versions and did a compare trying to find some thing different. Still not real sure which variable fixed problem.
0 -
As Roy mentioned, it is PLINETYPE which defines whether "old-style" or "lightweight" polylines are created;
3D polyline is unaffected :-)
many greetings !0 -
That appears to be the answer I have no idea why it would change. Not in my code in some ones code I have tried to hep with.
Thanks again.
0
