BRICSYS variant of accoreconsole.exe?
I don't see any executable in the BRICSYS folder tree that appears to be a flavor of accoreconsole.exe.
It's a very useful utility -- almost as useful as ODBX -- any chance that's on a [ ] todo list somewhere?
Maybe not exactly the same, but try using: bricscad.exe /automation
Thanks Owen. Is that documented somewhere or is it an undocumented argument? I didn't see it at http://tinyurl.com/y37m4h2h. Many thanks.
The /automation switch is actually built into MFC and just came along for the ride, but it should be documented nevertheless.
See the Remarks section here: https://docs.microsoft.com/en-us/cpp/mfc/reference/ccommandlineinfo-class?view=vs-2019#m_brunautomated
Ha, you're awesome, thanks a lot sir.
Howdy, Stranger!
