DOSLib for BricsCAD V21 available
Thanks a lot Dale. Much appreciated again.
As always, thank you Dale! Your efforts are greatly appreciated.
??? ... in this zipfile is just ... DOSLib21x64.brx ... and no other version ???
Any news about Doslib for BricsCAD V22? Thanks!
Brilliant. Many thanks Dale :-)
Any news about Doslib for BricsCAD V23?
We're looking forward for the new Doslib for V23. Thank you, Dale!
Ditto on the need for v23 update for DosLib. That is the final utility that I need to get v23 totally functional with my custom utilities.
The main page for doslib says v23 is supported but the zip download does not include an update?
Looks like Dale has now fixed this issue :-)
If you are reading this. Thank you Dale! -
THANKS Dale!
I was stuck converting a lisp routine that was written to run in AutoCAD that was looking for DOSLib. Once I copied DOSLib23x64.brx across, the routine ran perfectly. Since switching to BricsCAD four or five years ago, the only time that we use AutoCAD was to run this routine. I guess we can finally say goodbye to AutoCAD.
From me it's a big thank you to Dale.
Howdy, Stranger!
