Prevent Colors from Mixing
Hi,
in a drawing are two lines: one yellow, one blue. The blue one is over the yellow on. The colors are displayed corectly in Bricscad. However, if printed to pdf, the colors mix, i.e. there is a green line.
How can I print the line with the correct color?
Bricscad:
pdf:
  • Hi Sbcad
    Set the variable "pdfmergecontrol" to your liking.
    Options are 0 or 1. Where 0 is Off and 1 is ON.
    Cheers
