Update from V20 to V21 - right click
Hi!
I updated from V20 to V21. I have a problem with right click. If I 'short' click then it repeats last command. If I 'long' click, than it shows other commands (cut, copy, copy with base etc.). What should I do to be opposite? So I need to be - short click for list of commands?
For everyone who will have the same problem. The solution is SHORTCUTMENU set to 1. In my case it was set to 19 by default after updating.
So... me again. SHORTCUTMENU works only for right clicks on empty space. If I click on the line etc right click repeats last command......
Howdy, Stranger!
