Snap settings
Hello out there!
Im having a problem i nead help with...... when i turn on snap it only seems to be active when i actually moves or inserts an entity. I would like the crosshair to move
between snappingpoints always, but i cant get this to work....... any ideas???
Anders Lindblom
  • I don't know way to do so,
    but I also would like to have that behavior with all time snap.
    As I am used from my other CAD and use it to temporarily
    control positions/coordinates from status bar.
  • Marijan
    edited February 19
    I've already discusced this theme in "https://forum.bricsys.com/discussion/36209/snap-and-movement-of-the-cursor#latest". It's the SNAPGRIDLEGACY command that is missing.
    I've made also a feature request and first got an answer that they really don't understand why someone would need this. In the second try with additional explanation they've said they would created a feature request task for this, but they could not promise if and when it will be implemented.
    I suggest that you also make a feature request. Because, the more people ask, the greater the probability that something will happen.
  • Thanx for your answers guys, then i atleast know that i dont have to look any more.......
    /Anders
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
