2 starter questions: How to keep walls connected to eachother? Way to connect to grid?
Just started with BricsCAD BIM (with a little experience from Revit LT). Followed the basic tutorials and now trying to go a little deeper. And I was wondering:
1 - I have multiple walls that I connect to eachother. How to keep them connected when I move one wall to another place? There doesn't seem to be a connection between the two.
2 - Is it possible to connect for instance a wall or a building to a grid? That when I change the gridline the wall changes with it?
I know...these are newby questions, but I cannot figure out if (and how) to fix this? Many Thanx for your replies!
First question solved:
1 - Use the BIM-drag tool: https://help.bricsys.com/hc/en-us/articles/360016537493-How-to-use-BIM-Drag
Second question still open!?
0 -
2.
No, not possible to bind Walls to a grid.
Same as Slabs can't be bound to Story Heights.On the other hand, with direct modeling tools, like BIM DRAG,
you can move a slab vertically and all touching walls will follow.
Or if you change a Grid Line, you can select a Face per each related
Walls and drag them all at a time, without losing connections.Bricscad has a destructive modeling approach with clever Tools.
Once used to that workflow it shouldn't be slower than more
parametric modeling approaches.0 -
Thank you for your reply Michael!
0 -
Hmmm...in the video from the Bricsys Help files the standard option with Drag is that entities stay connected...in my version it is standard that they are disconnected and I need to use the control to adjust this setting. Is there a way to change the standard value?
0 -
Yes, unfortunately that changed lately.
But there there should be a setting variable to switch back to previous,
if I got that right.
I just forgot which.It was in some BIM Thread lately .....
I think, answered by @Louis Verdonck0
