Grading in 2D need help
Hello,
I'm using the 2D Bricscad software, I only have this one. I want to draw a Grading (Talus, in French). I speak of a succession of lines which are automatically drawn perpendicularly, to show that a land is sloping. Here is what I mean : www.delicad.com/fr/flashtalus.php
Could you help me for this ; how to proceed ? I can't find the way to do it on BricsCad.
Thank you very much in advance,
I would knock 5% points off the grade for each time the student overrides the dimensions value.
10% off for each block they explode without a good reason to.(sorry, couldn't resist the temptation)
-joe
Did you read my post I have a couple that I use.
Howdy, Stranger!
