2D Entity Snap mode is Deselecting themselves
We have 4 seats of BricsCAD and this happens to one of us at least once every couple of weeks, for no reason they deselect. If I have Endpoint, Midpoint and center selected, then go to draw a line the endpoint is unselected.
Has anyone else come across this? Is there a solution to stop it from happening?
Thanks.
  • how do you remove extra posts?
  • I think you need to activate a forum moderator to do so.
    E.g. by "flag"ing your own post ?
    (Under your name, right beside the posting date)
  • I have had this happen, too. All of a sudden, in the middle of some command, I might notice all 2D entity snaps are cleared. F3 does not toggle back to recover the previous state. I have to re-activate each one individually. Seems to happen randomly. At least, I haven't figured out what triggers it. Some weeks, no problem. Other times, several times in one session, but I can't reproduce it.
