Text Align - is there an equivalent command to Autocad TEXTALIGN in bricscad?
I don't know of a command but you can select one. copy it's x postion in the properties window. Then select the rest of the text and past that number into their x position and they will all be aligned as long as they were using the left justify.
Well,
it looks like there is no straight forward solution in bricscad,
so Lee Mac to the rescue again... -:)
I've found a lisp that do the job in this Lee Mac link: http://www.lee-mac.com/aligntext.html
Ari.
Howdy, Stranger!
