Section Planes & POintclouds
AFAIK latest V21.2 will allow to create any Solid Geometry
to be assigned as a Clip Volume for Point Clouds.
(If I read release notes correctly) -
section planes are supposed to work on pointclouds too. And as Michael mentioned, there's a new functionality in V21.2 called POINTCLOUDCROPSOLIDS, which enables you to convert an extruded solid (a BOX or CYLINDER for example) to a 3D cropping entity for pointclouds.
If you can't even crop the pointclouds with POINTCLOUDCROP I would suggest you fill in a support request so that the issue can be examined further.
Howdy, Stranger!
