Sections through point clouds?
pcVS
edited April 2021 in Point Clouds
got my point cloud into the drawing and setup the section plane but using SECTIONPLANETOBLOCK gives me an empty drawing - is it possible to generate sections from the point clouds?
V21 PRO
  • Yes, it is. You can use POINTCLOUDPROJECTSECTION command. Keep in mind that this command needs to be performed on a section VOLUME, which basically projects all the point of the point cloud inside the volume onto a plane and creates a raster image.
    So just make a BIM section, change its state to volume, and make it a thin volume (like a slice). Then run POINTCLOUDPROJECTSECTION to get an image of the section.
