Import .RCP for BricsCAD point Cloud
MarchNguyen
edited April 2021 in Point Clouds
Hi all!
When i import a file .rcp into BricsCAD V21 then receive a notification as: "Error in initializing file reader for C:\Users\Admin\Desktop\Combined.rcp (check 8 or 16 bit data)". after that I get no result of point cloud model appeared. if anyone solves this problem, please tell me.
  • Hi March,
    It is hard to tell why this issue occurs just from this error message. Can you please file a support request so our developers can have a closer look? https://www.bricsys.com/protected/support/NewSupportRequest.do
    Kind regards,
    Chi-Yan
  • @MarchNguyen said:
    Hi all!
    The error means that the software component to read the rcp could not be initialized. This usually means there is something wrong with the data... But to be sure, it would be best if indeed we could have a look at the software with your data and check what exactly goes wrong...
