Visual Styles Manager - Edit box
After using this function for the last year or so I can longer access the edit box within the Visual Styles Manager. I have tried on both previous version V21.2.01 and new update last week V21.2.02, to copy and edit also but still won't allow me to edit depending on client/job requirements. This function was really helpful as the style only applied to that particular model during editing.
Cheers
Murray
  • Hi Murray,
    This function is still there in V21.2.01-V21.2.02. Make sure your Editor option in the View tab of the Drawing Explorer is turned ON. See image attached.
    Kind regards,
    Chi-Yan
  • Chiyan
    Thanks for prompt reply. Yes, I did have Editor turned on, however I just tried restoring defaults within Settings Menu and now it works fine but thanks again.
    Cheers
    Murray
