V20 Seems well
I have been doing some significant development on V20.2.10 Linux. It seems to be functioning well with very few issues.
One annoyance is the tool bars keep changing on their own. I have not quite got that figured out yet.
I copied the cui files over to a different directory to see if I can copy them back as needed.
Escain, Thanks for responding.
Here is a picture, it happened again this morning. I have been stopping and starting BricsCAD often. 50 times per day beta testing my application. I opened up my example and all of the toolbars are gone or moved, just a different setup. In the past, I have set everything back to default, deleting my custom toolbars, then I learned to create a custom cui file and reload them.0 -
Yes.
Experienced that to since I started testing Bricscad in 2014 (?)
Customizations and GUI in general are still not stable, or on the Windows level,
in Linux and Mac versions of Bricscad.I personally gave up and avoid any deeper UI customizations and just reactivate
my disappearing or changing Palettes on Mac/Linux every now and then ....0 -
I copied my default.cui file when the toolbars were working to a master copy. I just copied the working default.cui back and the toolbars are visible again. I hope this is the fix. I think the cui file is getting corrupt.
This is great BricsCAD runs on Linux! I don't mind a few annoyances if there are easy fixes.
0 -
Hohoo! I see.
To be honest, I work mostly with "Ribbon" and have only one of those toolbars, and so far it seems to stay in place. Indeed seems like a bug.Do you have some of the toolbars produced by a plugin? ( I just wonder if it could be related to the plugin loading order)
I would just report the bug.This is great BricsCAD runs on Linux! I don't mind a few annoyances if there are easy fixes.
Yes, and no: as we are less using Linux, it seems also important to kindly report bugs, so it can improve.
0
