Looking for cut optimizing tool for things like plywood to cover roofs
I have found many programs that can optimize cuts for 1D material, and for multiple parts placed onto 2D panels. However, I want to optimize materials for things like putting a metal floor into sheds, with each shed being a different size. Attached is an example of what I am needing to do.
Any suggestions?
-Joe
0
I kept getting the error message, "try again in 30 seconds." when I clicked to post the message, and did Apparently, in spit of the "try again" message, each attempt went through. So, that is the reason for the multiple posts.
0 -
Happens to me all the time, they need to fix this.
0 -
Thanks, I will check them out.
0
