Civil addon for BricsCAD
Hi,
CadTools, 3D and surface utility for AutoCAD and ZWCAD is now available with support for BricsCAD (Select BricsCAD as CAD version in the settings form)
https://www.glamsen.se/CadTools.htm
  • edited August 2021
    Lars, thank you so much.
    Your CAD Tools are absolutely great and thanks for sharing !
    I am no Civil Engineer, so I may not need most of the Tools.
    But there are some pearls like Layer Visibility Switching which
    I sent many feature requests since years.
    And I wished Bricscad would include such fast Layer switching.
    All OFF but active and such things.
    If you read through all your features, you can see a quite comprehensive
    list of things where Autocad failed or was just ignorant. All things you
    would expect being just mandatory.
    Thank you for your kind feedback.
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
