Line tangent to 3D spline?
Hi All,
Is there a way to draw a line tangent to a 3D spline at some arbitrary point on the spline?
You can draw a line Perpendicular to a 3d spline in a specific plane, then perp to that in the intersection.
You really need to know what plane you want the tangent in. Set the UCS the align your view. -
Here is some Lisp code:
(defun KGA_Geom_VectorScale (vec scl) (mapcar '(lambda (a) (* a (float scl))) vec) ) (defun KGA_Geom_VectorUnit (vec / mag) (if (/= 0.0 (setq mag (distance '(0.0 0.0 0.0) vec))) (KGA_Geom_VectorScale vec (/ 1.0 mag)) ) ) (defun c:DrawTangent ( / doc enm len pt vec) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (if (and (setq enm (car (entsel "\nSelect curve: "))) (setq pt (getpoint "\nPick point on curve: ")) (setq pt (vlax-curve-getclosestpointto enm pt)) (setq len (getdist "\nLength of line: ")) ) (progn (setq vec (KGA_Geom_VectorUnit (vlax-curve-getfirstderiv enm (vlax-curve-getparamatpoint enm pt))) vec (KGA_Geom_VectorScale vec (/ len 2.0)) ) (entmake (list '(0 . "LINE") (cons 10 (mapcar '- pt vec)) (cons 11 (mapcar '+ pt vec)) ) ) ) ) (vla-endundomark doc) (princ) )
Here is some Lisp code: [snip]
Excellent!
One of these days I really need to sit down to go through the VLAX- and associated documentation...
Howdy, Stranger!
