Revit import
Hi, I have the extension to import/export different extensions.
However, when I import a revit package from Wavin https://www.wavin.com/nl-nl/catalogus/binnenriolering/geluidsarm-afvoeren/wavin-as (I cannot add it since the file is too large) and import it in bricscad I only get a couple of strange objects (see screenshot). How to import it the correct way?!
Hi Bas,
I don't know which version of BricsCAD you are using, but I tried to import a .rvt file from that site to BricsCAD V21, and noticed that the import is indeed incomplete (it was another file than yours, but I got similar results).
However, we will include many improvements to the .rvt import in the upcoming V22 release (to be released end of October). When trying with a V22 beta version, all geometry seems to be imported correctly. (see picture).
In the meantime, you can try an alternative approach: open the file in Revit, export to .ifc, and import the .ifc file in BricsCAD.
Hopefully this helps.
Best regards,
Ruben -
Thank you for your reply. Unfortunate I don't have Revit. Another solution for this moment?
Howdy, Stranger!
