Is there a way to get the weith of a volume?
Hi there! I use BricsCAD in my work and I need to calculate the volume from the point cloud rised before. Is there a way to do it in this software? Thanks!
I don't think there is any option to calculate it directly from the Point Cloud.
Which is - just a dumb Cloud of - Points ...
If the geometry isn't too complex, you may need to manually draw in some
Solids, which will give you the Volume.0 -
Much improved detection of planes, solids even, is trailed for v22, so this shd be poss, if not already?
0 -
Plane detection and those things will already help to create Solids.
But if not too complex, just snapping and using Direct Modeling
maybe even faster (?)0 -
You can use POINTCLOUDFITPLANAR to fit planar surfaces (or even solids, in case of room-like structures) on your pointcloud. This way you might be able to convert your pointcloud to geometric entities and then get the volume.
https://help.bricsys.com/hc/en-us/articles/360018700139-PointCloudFitPlanar0
