Chamfer a wall
Various ways to do it depending on what you're after. In example below, first I chamfer the end of one wall by CTRL-selecting the edge and using the
_DmChamfercommand. Then I make a chamfered corner by adding a polysolid, assigning the same wall composition, and then_LConnectit to the adjacent walls.
0
