V19 Crash - customer side.
Does your customer really uses V19 ?
The error comes from (attempt to) loading a "CADEARTH21-64B.ARX" module, seems from CADEarth application ?
And as the name implies, that module is intended for V21 ?
So your customer has to review his/her CADEarth installation ... eventually installed the wrong version ?
In worst case, she/he has to contact CADEarth developer to investigate + fix the installation ...
hope this explains & helps a bit ?
many greetings !0 -
@Torsten Moses
Hi.
first,
yes - he dose use V19...
I've asked him to check if Cad Earth is installed on his machine, and if it is so - to uninstall it.
apparently, Cad Earth was installed on his machine (he wasn't even aware of that...),
so he uninstalled it and the problem was solved.
Thanks,
Ari.0
