WANTED : extrim.lsp or (etrim) function
I want to be able to use extrim programatically like :
(etrim <ename> <point>)
The function is not found even though i have ExpressTools installed.
I found this : extrim.lsp
but won't function in my Bricscad V21 since it cannot find another missing function (BNS_TRUNCATE_2_VIEW)...
There is a version of express tools for Bricscad it may have a different extrim.lsp
Look at cookie-cutter.lsp also.
Hello,
that "BNS_TRUNCATE_2_VIEW" function is part of ExpressTools, so you need to install the ExpressTools for BricsCAD as well (in appropriate version); then your extrim.lsp should work (?)
many greetings ! -
You can give this one a try and see if it works for you.
https://b-k-g.nl/bkg_extrim.html -
@ALANH, @Torsten Moses , I do have Express tools installed and no luck; neither etrim, nor BNS_TRUNCATE_2_VIEW are found functions. Do you get the lisp to work? I can't...
@David Waight, Thanks, but this is a licenced app which annoyingly prints a voucher. It is thence not suitable for my office.
I guess i'll have to modify CookieCutter myself to get my own silent function...
(which i knew of, yes, but who does not perform without active user input) -
I am the author of that application. It is a free application that certainly does not print a "voucher" (whatever that means).
I tried to edit my previous post. But that is no longer possible for some reason.
Every time the lisp is loaded, I get :
BKG_Extrim - Program version 20141027 Copyright (c) 2011-2014 Roy Klein Gebbinck - All rights reserved Use: BKG_Extrim or BXTR
Since all our office tools are loaded from ON_DOC_LOAD.lsp, so at every drawing, this is annoying...
Again, since i am trying to use the etrim function inside another automation function, i can't use this.
But it works great, no offense to your skills!
So i came up with this simple solution :
; Say you drew some regular 2D entities (lines, polylines and hatches) and a cutting line entity over these (defun c:TrimTest (/ DrawnedInfLine SidePt offsetename offsetPts1 offsetPts2 ) (setq DrawnedInfLine (car (entsel "Pick the cutting line :"))) (while (= SidePt nil) (setq SidePt (getpoint "On which side do you want to cut?"))) ;(etrim DrawnedInfLine SidePt) would have been nice here and i would have been over for this part... (vl-cmdf "._Offset" (/ (getvar "VIEWSIZE") 75.0) DrawnedInfLine SidePt "_exit") (setq offsetename (entlast) offsetPts1 (trans (cdr (assoc 10 (entget offsetename))) offsetename 1) offsetPts2 (trans (cdr (assoc 11 (entget offsetename))) offsetename 1) ) (command "_.Trim" DrawnedInfLine "" "_Fence" offsetPts1 offsetPts2 "" "") (entdel DrawnedInfLine) (entdel offsetename) )
Which works great on most of my attemps. But for some reason, on some attempts, there will always be 1 or 2 lines that are not trimmed... and i don't know why.
It may be related to the use of a fence in the Trim command?
Thoughts?
It seems to be related with the linetypes! Using a fence crossing a visible hole in a dashed linetype will not trim this line.
I'm in contact with Support to find a solution. -
That's pretty much AutoCAD compatible behavior. Seems unlikely that BricsCAD will change it.
That's pretty much AutoCAD compatible behavior. Seems unlikely that BricsCAD will change it.Actually, recent versions of AutoCAD introduced a new variable to control how selection in gaps behave.
AutoCAD 2018 Help: LTGAPSELECTION (System Variable)
help.autodesk.com/view/ACD/2018/ENU/index.html?guid=GUID-C3816CB5-ED9D-4F7B-8F1A-C974E17D0FF7Regards,
Jason Bourhill
BricsCAD V22 Ultimate
CAD Concepts -
I'm in contact with Support to find a solution.A workaround would be to temporarily change the LTSCALE to a large number, which would essentially make the linetype appear as continuous. Alternatively, assuming you have MSLTSCALE = 1, you could simply change your Annotation Scale on the status bar to give a similar effect.
Regards,
Jason Bourhill
CAD Concepts -
This wouldn't occur if you used AUTOLOAD instead of LOAD in your on_doc_load.lsp
e.g.
(autoload "BKG_Extrim.des" '("BKG_Extrim" "BXTR"))
You will still see the messaging, but only when the command is invoked for the first time.
Regards,
Jason Bourhill
CAD Concepts -
AutoCAD 2018 Help: LTGAPSELECTION (System Variable)Thanks. Good to know. This means that BricsCAD can do the same.
Jason Bourhill
CAD ConceptsYes! LTGAPSELECTION totally solve that problem.
Now i just need to wait for a HATCHGAPSELECTION variable... Non-solid hatches have the same problem.@Jason Bourhill said:
e.g.
Regards,
Jason Bourhill
CAD ConceptsGood idea, that's right! but still... i cannot use it from within another LISP.
Howdy, Stranger!
