Palette Functionality
Palette-based content availability proved convenient in a (barely) competitive CAD application. Can someone comment on any efforts in adding either this exact or similar content organization functionality to BricsCAD?
0
Have you looked at the old fashioned image menu's as a solution ?
0 -
It is a solid option. Thanks!
0 -
BricsCAD has palettes. Unless you have a very old version you should be able to use them.
0 -
I will explore the newer version now. I thank you!
0
