Non Real-Time PAN
hi all -
i used to use pan in it's non-real-time mode quite often - panning using pointing a direction and entering a distance.
just bought the V22 version, and it appears that PAN command does just what the PAN Real-Time is doing.
searched SETTINGS for a variable definition - not found one.
ideas, anyone ?
(i can clearly see a distinction in the icons of PAN & RealTime PAN)
You are looking for the -PAN command.
https://help.bricsys.com/document?title=commandreference/CMD-pan.html&documentVersion=V220 -
Correct link is:
https://help.bricsys.com/document?title=commandreference/CMD-pan.html0 -
Mmm, still doesn't link correctly ...
Alias for _-PAN is -P0 -
Alias for _-PAN is -PThanx Louis -
indeed the TYPING the command works out -
problem is i can no longer assign a key to it the way i'm used to (Customize>>Keybord), since it isn't available among the other functions under the View category (actually, it DOES appear as an icon - same one i had in earlier BC version, only now in V22 it functions as RTPan and not as -PAN)
:-(0 -
Alias for _-PAN is -Pi smply changed the sintax of the command in the proper CU>>Keyboard>>specific key, to -PAN as you said - and it works !
Thanx, louis !0 -
You can also edit the Pan tool in the View toolbox (CUSTOMIZE dialog box: Available tools / BricsCAD / View) and type a minus character in front of the command: '_-pan.
By default the Pan tool is available in the Zoom toolbar.
To easily repeat the command using a 'long right click' (= hold down the right mouse button a bit longer): set SHORTCUTMENU=22. Even when 'Show Quad on right click'=yes, the previous command will be repeated.0 -
To easily repeat the command using a 'long right click' (= hold down the right mouse button a bit longer): set SHORTCUTMENU=22. Even when 'Show Quad on right click'=yes, the previous command will be repeated.thabx, Louis -
both Tips were very useful !0
