Cursor snapping to an apparent hidden net, while drawing entities
hi all -
SNAP mode is off, ESNAP is also off
Attempting to draw a line, the cursor snaps to an apparently unseen net.
drawing sequence of lines - each starting from to nearby "snapped" points, indicates the net's gaps are consistent.
would appreciate a help on the variable disabling this hidden net functoinality.
regards,
Assaf
What is the value of the SNAPTYPE system variable? When it is 2, Adaptive Grid snap is active. Set the value of SNAPTYPE = 0.
See https://help.bricsys.com/document?title=_guides/BCAD_drawing_accurately/GD_adaptivegridsnap.html&documentVersion=V22 for more information about Adaptive Grid snap.0 -
See https://help.bricsys.com/document?title=_guides/BCAD_drawing_accurately/GD_adaptivegridsnap.html&documentVersion=V22 for more information about Adaptive Grid snap.Thanx a lot !!! That has solved the issue !
0 -
GRID and SNAP can do what your talking about, turn them off
0 -
@ALANH said:
GRID and SNAP can do what your talking about, turn them offIt's definitely the value of the SNAPTYPE system variable that this issue is about. If SNAPTYPE=2, SNAPMODE is ignored.
0 -
Indeed so ! Thanx
0
