Can't get the effective name of a parametric block after changing its parameters.
aridzv
edited January 2022 in LISP Codes
Hi.
I wrote a LSP that gets a parametric block effective name (see EF.lsp).
but when I pick a parametric block I get the anonymous blocks *U* name.
as its tured out,
as long as I don't change the plock parameters I can get the effective name,
but after changing the parameters I can only get the anonymous name.
I also attched a simple parametric block flie to use as an example.
dose any one has an idea on how to solve this issue?...
thanks,
Ari.
  • Hi Arid,
    could you try
    (setq instHandle (BmLispGet "Instance" ent))
    (setq instName (BmLispGet "InstanceName" instHandle))
  • aridzv
    edited January 2022
    Piet said:
    Hi Arid,
    could you try
    Hi Piet.
    I tried your suggestion with VLA object and a regular one.
    in both cases I get NIL...
    see the lisp I'm using:
    (defun c:EF11 ()
    (vl-load-com)
    (setq obj (vlax-ename->vla-object (Car (entsel))))
    ;;(print (vla-get-effectivename obj))
    (setq instHandle (BmLispGet "Instance" obj))
    (print instHandle)
    (print instName)
    (setq obj1 (car (entsel "\nSelect Block ")))
    (setq instHandle (BmLispGet "Instance" obj1))
    (print instHandle)
    (print instName)
    (princ)
    Thanks,
    Ari.
