How to Create a Solid Surface from a TIN Surface then Output as STEP File
Please excuse my lack of design knowledge - a Surveyor talking here......
I have to create a CNC file from a survey model which is irregular. It is a bearing plate for a bridge which is attaching to another plate that has been damaged and warped.
I primarily use 12d and have limited knowledge with BricsCAD but I know how to create a TIN Surface in BricsCAD. But I need to make this a solid surface so I can export it as a STEP file for CNC machine cutting.
Does anyone have any knowledge of the process of going from TIN Surface to a solid surface that is "water tight" and then exporting that as STEP format file?
Any light on this would be appreciative.
Cheers
Chris
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
Welcome!
