Render Viewport
Hi,
When I try to render viewport, time goes by, the viewport flashes, but I don't get my rendered object. If I render to a window, it works as expected.
Is there a setting I'm missing to render in the viewport?
Thanks
Joel
Thanks
Joel
0
Hi Joel_I,
Sorry to hear about this. Which version of BricsCAD are you using and what PC specs have you got? It might have something to do with your graphics card/ hardware.0 -
Hi,
It's an ASRock Taichi X399 with a Threadripper 2950X, 64GB ram, NV GTX1070 running the studio driver.
BC V22.1.06
Joel0 -
Thanks Joel.
A quick check over here on redway3d (http://www.downloads.redway3d.com/downloads/public/documentation/bk_ba_gpu_chipset_reference.html) shows that your graphics card model is supported so it does not seem to be the problem.
Did this issue you are experiencing happen after a recent driver update? If so, please try a driver rollback to see if it appears again. Otherwise, I would suggest you send a service request ticket so our developers could look at it closely.
Thanks0 -
It has always happened. I am new to Bricscad and 22.1.06 is my first version.
I have this same issue on my laptop, an HP Fury 17" with RTX3000 graphics.
The rendered image flashes for a moment <1second and is back to the modeling view.0
