Polar Extension of lines
I recently upgraded from V21 to V22 and one of the settings I can't get enabled is polar extension as shown in the attachment. When I draw lines I like having the polar extension magnets allowing me to draw the vertical line to a length of 10'-8" and 3'-7" off from the corner of the red box off to the left of the image.
0
Have you turned on Polar tracking, try hitting F10 (the polar tracking toggle) to see if this does the trick for you... Edit, I can see after playing in my system that is not the issue that you are seeing, do you have snap tracking enabled? Try toggling this with F11...0
