Library parametric Objects
Hello,
while in the standard library there are many parts, the choice of available screws is limited. We are missing different types of screws that we use frequently. Is there a way to add parametric objects to the standard library or create it's own parametric objects library?
  • I am looking to use calculation with parametric block is there a way of using the same type of calculation that are used in excel
