units
                    I haven't found a solution for this - the units I set in my drawings is almost always feet.  When I select the entity and display properties, the unit value is listed in miles.  If anyone can help I would be appreciative.
John
                John
0
            When you start a new dwg it uses a predefined dwt, you can change the dwt setting, Config, Files, Templates set it to your dwt or a metric one.0
Can you post a .dwg file in which that happens? And please indicate which entity has its length shown in miles on the Properties panel.jloacker said:.... the units I set in my drawings is almost always feet. When I select the entity and display properties, the unit value is listed in miles. ....
0
