Adding fields values in title block from Component
How do we add Field values from a component into the title block.
I have a part that I want to send to a supplier for manufacturing.
I need the material to be part of the title block and also be linked to the component or assembly in the viewport. Should I change the material they need to be synced.
  • Sadly mechanical properties cannot be linked into fields yet.
    You can link drawing properties like "Author" or "Date" to a mtext field.
