Publish without Prefix sheet title with filename
C_Wilms
edited September 2022 in Printing and Plotting
Maybe I am missing it but in AcadLT (And AutoCAD full version) I could change the pdf output filename to include or exclude the drawing filename when batch plotting/publishing.
Is this possible in BricsCAD? I want to use only the TAB-name most of the times.
Added: Maybe add the posibility to use (custom) drawing propperties. At least we want to do better then that other company, don't we?
