BricsCAD V23 Point Cloud
Every time I reference a RCP file in Version V23, BricsCAD closes down without any messages. any help?
I just tested with several RCP/RCS files and couldn't reproduce the problem.
Maybe there's an issue with your RCP file. Have you tried to attach another RCP file?
I suggest you create a support request so we can have a closer look. -
Yes, I tried many different RCP files and I have the same resultomid.ekrami@hexagon.com said:I just tested with several RCP/RCS files and couldn't reproduce the problem.
I submitted a support request as well, Thanks
Thanks, we'll have a look at the issue.
In the meanwhile, maybe one other option might help.
Go to SETTINGS, Point cloud settings, and disable "HSPC mode". Then try to attach the pointcloud again.
If the point cloud appears then we'll have more info to find the root of the problem. -
I am using V23-Pro now and getting the following when importing a new PC to the cache
Seems to be doing it twice though I know I only asked it to do it the once.
Also you don't seem to be able to delete them now. I tried deleting the "Test Run Exterior" one and no joy.
Never had any of this in v22.
@Just_Me it's definitely strange that the preprocessing is run twice for the pointcloud. Does this happen everytime you want to process a new pointcloud? If so, please create a support request so we can followup on the issue.
Regarding deleting the pointcloud, from the scroll bar at the bottom of the reference manager I would say you just need to scroll right or resize the window to see the delete button. -
I will test once this one has finished, it's a 100GB one so taking a while. As for the delete option, you are corect on that. Strange it didn't size sufficiently to see it as I'm on a 4K display.
Turning that HSPC mode off I believe worked, at least on one it did, I'll try another rcp and will let you know. THanksomid.ekrami@hexagon.com said:Thanks, we'll have a look at the issue.
I've also just updated V23 to latest build and a tiny 4mb .LAS point cloud is running like a total bag!
Howdy, Stranger!
