Bulk editing of drawing stamp on multiple layouts?
maknu
edited November 2022 in Moving from A-CAD
Hi,
Moving from Acad to Bricscad I'm lacking a tool to bulk edit large amounts of drawings in one go. we have a dedicated software for Acad where I can import a folder with drawings (or multiple drawings directly) and I can then choose which block to edit (drawing stamp in my case) and bulk edit stamp content. Very smooth and I can also use csv/txt and as an example create an excel sheet with all the stamp content be it 5 or 500 drawings and then just import the csv and populate each drawing stamp. I wonder if there are any Bricscad addons or similar that does this? The soft I'm using today is a stand alone and I look for more integrated UI if possible.
Cheers,
Mats
