Bulk editing of drawing stamp on multiple layouts?
Hi,
Moving from Acad to Bricscad I'm lacking a tool to bulk edit large amounts of drawings in one go. we have a dedicated software for Acad where I can import a folder with drawings (or multiple drawings directly) and I can then choose which block to edit (drawing stamp in my case) and bulk edit stamp content. Very smooth and I can also use csv/txt and as an example create an excel sheet with all the stamp content be it 5 or 500 drawings and then just import the csv and populate each drawing stamp. I wonder if there are any Bricscad addons or similar that does this? The soft I'm using today is a stand alone and I look for more integrated UI if possible.
Cheers,
Mats
Cheers,
Mats
0
Is the software a lisp, fas or arx the last 2 can not be edited, need to be recompiled to suit Bricscad.0
You may want to have a look at JTB World BatchAttEdit, it can edit block attributes across multiple drawings, either already open in BricsCAD or by loading the files into BatchAttEdit. Perhaps it is what you are looking for.
It is in the Bricsys application store:
https://boa.bricsys.com/applications/a/?jtb-batchattedit-a1309-al22880 -
maybe. will look into the batchattedit. thxRSW said:You may want to have a look at JTB World BatchAttEdit, it can edit block attributes across multiple drawings, either already open in BricsCAD or by loading the files into BatchAttEdit. Perhaps it is what you are looking for.
