Can not get Communicator V23 to install
Running BricsCAD V23 on M1 Max MacBook Pro. BricsCAD works fine.
Purchased Communicator V23.1-2.05 and have Finder permission granted, set environment variable in BricsCAD to point to the application, but the License Manager keeps telling me Communicator license is Active, but Not Installed.
Using CommunicatrINFO command yields:
'CommunicatorPath' setting has incorrect value or Communicator installation broken.
Resetting the path and downloading and reinstalling BricsCAD Communicator V23.app does not work.
Set USECOMMUNICATOR to 2 in the command line, quit program, restart and nothing changes.
What should I try next?
  • Fixed. I found out you must add the application's name to the path as well as a /.
